Acceptable to substitute plasma cut hole for drilled hole?
I am wondering if it is acceptable to substitute a plasma cut hole for a drilled hole in a cyclically loaded structure (bridge).
I originally posted this in the structural forum but I suspect that some of the members monitoring the Machining topic might have some great feeback. Here is the link to the OP: Link
Thanks!
