NX Nastran - Post View Defaults
NX 8.0 Advanced Sim - Nastran Solver.
Is there anyway of setting: Deformation = Absolute Scale 1 and Edges & Faces = Feature as a default ?
I've look through Utilities / Customer Defaults and can't find anything.
Cheers
Neil
RE: NX Nastran - Post View Defaults
I don't think there is anything in Customer Defaults. Have you tried using Templates? These can be customised then dragged and dropped onto the post view.
Create your Postview -> set your user defined settings ("Deformation = Absolute Scale 1 and Edges & Faces = Feature ") -> RMB on PostView -> New Template -> RMB on created template -> Make Default
Creating a new PostView these settings should be applied by default.
Cheers
Thanks. default template did the job.
