MPC Beam designation
I am looking at plans from the early 80s for floor framing for a mall in Southern California. Concrete over steel deck construction
The beams are called out with MPC designations- i.e. MPC 16 1/4 X 20.4 <15>-1/4.
These beams are spaced up to 10 feet on center and span approx 30 feet.
Does anyone know what this member is?
RE: MPC Beam designation
Have you tried calling up the design firm that produced the drawings, if they are still around or have morphed?
Mike McCann
MMC Engineering
http://mmcengineering.tripod.com
The prior company is gone (30+ year old job). Unfortunately, the responces to the prior post listed above were 'I don't know'.
Thanks for the suggestions
Did another firm buy that company and maybe the access to the drawing files is still there?
Mike McCann
MMC Engineering
I have the same issue on a shopping center in San Diego that was designed in 1980. For example, MPC18 1/2 x 25.7 (15) 1/4. I take that as a steel composite beam with camber. (But who'd camber something 1/4"?) I can't see it because it has sheet rock over it.
A general section shows it like a composite W shape. There's no definition of it on the plans and even the connection details/schedules ignore it completely.
The engineering company has a fancy symbol that looks like GKT Consulting Engineers in Marina Del Rey.
I guess I'll find out what it is eventually because I have to drill holes for plumbing in it.
As far as hawkaz's original question, I did some cyberstalking using some NSA software last night. The engineer who sealed the plans is still registered in Arizona and his address is in St. George, Utah. I can't guarantee he's still alive, but that's a lead. Plus there's some linkage to a company in San Diego.
Since this has been posted twice and the greatest Eng-Tips minds can't solve this, I would give him a call. Or call the original structural engineer's successor company.
Obviously he retired there to slay his dragons too. Great little town, by the way.
Mike McCann
MMC Engineering
From SoCal mall drawings around 1980: MPC designation is for Marcrest built-up wide flange beams. From those drawings,
MPC16X20.2: h=16.25" tw=0.185 bftop = 4" bfbot = 5.75" tftop = .312" tfbot = 0.312"
Hope this helps.
