Rotate Command For Products In The Product Environment
Using CATIA V5R18;
Is there a rotate command that can be used on products in the product environment, which will maintain the new reference with the view compass reference? Similar to the part body “rotate” command in the part environment?
An example; I insert an assembly that has a reference hole at 4 o’clock in the default view. I would like to rotate the entire assembly so the reference hole is positioned at 12 o’clock but I don’t want to change the compass settings. Is this possible?
Any response will be greatly appreciated!
RE: Rotate Command For Products In The Product Environment
Derek
Win XP64
R20SP7/21SP5, 3DVIA Composer 2013, ST R20
Dell T7400 16GB Ram
Quadro FX 4800 - 1.5GB
If you want your sub level 4'oclock to be at 12'oclock in root product, you could write a script that would change the position matrix of your sub level.
If you want to change your sub level 4'oclock to be at 12'oclock of your screen you could create a view with a new camera oriented properly.
Does that answer your question?
