DraftSight block attributes
When inserting a block with editable attributes, can I set DraftSight to automatically open a window to edit in, rather than entering the attributes at the command line? We are trying to make an easy entry method for users and remembered this as an option in Acad, and hoped it was available in DS.
Thanks, Diego
Thanks, Diego
RE: DraftSight block attributes
You can edit a Block via MODIFY,PROPERTIES.
You are able to vary Posion, Dimensions and Text this way.
Hope this helps.
David, from Downunder.
