Buried pipework
Buried pipework
We have a potential to have some buried gunited pipework that is 1000DN. I have never seen this installed before. How is it supported? I am presuming in the conventional way except every support is attached to a big block of concrete?
RE: Buried pipework
RE: Buried pipework
If the pipe is buried then you have total support.
If the pipe has rubber ring joints then concrete thrust blocks are only required at changes of direction, slopes or ends of pipes.
Suggest you invest in Structural Design of Buried Pipelines by Watkins or Buried Pipeline Design by Moser.
“The beautiful thing about learning is that no one can take it away from you.”
---B.B. King
http://waterhammer.hopout.com.au/
RE: Buried pipework
thrust block and anchor block only needed for mechanical joints, bell and spigot joint and coupling joint and not for butt welding joints.
RE: Buried pipework
RE: Buried pipework
