Tooltips image in NX8.5 manufacturing
Its possible change showing images permanently as NX8 (disable tooltips)?
NX 8.0.3.4
RE: Tooltips image in NX8.5 manufacturing
:) It has been quite a long time since i used UI Styler (NX have both BLOCK UI styler as well as Pre NX6 UI styler ..go to Start and in the last you may find these two applications (based on the license you have)).
Open the related dlg file (i am attaching an image of one example but you may need to search for the relevant .dlg file in your case ..just search for *.dlg in the NX installation folder.Hopefully you will get what you want.) .I opened it using PRE NX6 UI STYLER.
You will notice that you can access and change the .bmp (or any other picture ) or basically the icon picture from the resource editor.(as shown in the picture).
*Note: In case you didn't find the relevant .dlg...there may be a possiblity that you may have to search for the .dlx files also (since i am not sure about how it was developed) .The .dlx file can be opened through BLOCK UI styler .
But i will suggest please do it with the consent of your IT admin colleague.(or at least take a back-up of the original .dlg file.)
Best Regards
Kapil Sharma
NX 8.5.1.3
Anthony Galante
Technical Resource Coordinator
NX5.0.6, NX6.0.5, NX7.5.0-> NX7.5.5 & NX8.0.0 -> NX8.0.3.4, NX8.5.0.23
NX 8.5.1.3
Mark Rief
Product Manager
Siemens PLM
NX 8.5.1.3
