Another Catenary Question
Getting myself all confused again!
Typically I find I have a cable I want to know the component reactions at ends of. Lets just assume a hanging cable, equal elevation on supports, gravity load only.
Information I have/can get:
L = Horizontal length of cable
w = weight of cable or UDL on cable, gravity for example
s = Sag (distance at centre from cable to horizontal)
The vertical reactions are fine, purely "w x L / 2". Simple.
The horizontal reaction is something I see conflicting information on.
1. Can I just use "w L ^2 / 2 s" to calculate my horizontal reactions?
2. What would I need to calculate/estimate cable TENSION at ends?
3. What would I need to calculate the Angle at ends? (if i can cal Tension and Angle I can break it back down into components).
Thanks!
Thanks!
RE: Another Catenary Question
I believe your formula for horizontal reactions is correct.
Once you have answered number 1, you have also answered numbers 2 and 3. You have your vertical and horizontal component....just draw your triangle and solve for net tension and angle.
can I derive answers to 2 and 3 using a different formula?
Maybe something to calc the angle at end?
Quando Omni Flunkus Moritati
The magnitude and instantaneous slope at the ends can be found using Pythagoras!
Michael.
Timing has a lot to do with the outcome of a rain dance.
If you are using the parabolic approximation, then the horizontal reaction at each end is wL2/8s. That is also the horizontal component in the cable throughout its length.
The tension at the ends (again using the approximation) would be (H+V)1/2 where H and V are as calculated above. The angle from horizontal is arctan(V/H).
If the cable has appreciable sag, these formulas are not correct. You would have to go to catenary equations which involve hyperbolic functions.
BA
Clears it up.
Say I wanted to use the hyperbolic equations, which ones get me what I want. I see a few with "a" in them, which is just a scaling factor for the shape. How does this relate back to a real world situation?
Typical smallish tensioned membrane structures.
BA
Not sure on how to use your spreadsheet.
For one, it just gives me an error when running the solver. Runtime error. Macros are enabled.
But the input values I'm not sure of. If I had a cable with no point loads, just simple weight, what would be an example input? Do I need to calculate the "Unstretched Length" of the cable?
Page 21.
For a tension membrane (shade sail) structure, it is saying that Tension in the cable is simply Fabric Prestress x Radius (I can't quite seem to reason this formula in my head though).
Now this obviously makes the assumption that the curve is circular.
So I come to the predicament of if I treat it as Circular, Parabolic or Hyperbolic it seems.
Michael.
The error when running the solver is probably one of two things. Trivial one first: maybe you do not have the solver add-in installed, in which case you will need to fish out your installation disks and install it, then you will need to activate it (by taking Developer>Add-ins, then ticking the appropriate box.)
The other possibility is that you need to "make the solver available" to the VBA environment. This is not the same thing as making the solver available to the Excel environment. Fire up Excel, get into the VBA environment, take Tools>References, find Solver in the list that appears and check its box. (If you cannot find it, you might need to "browse" to it. If your Excel version is <12 you are looking for Solver.xla, if your version is 12 or greater you are looking for Solver.xlam.)
If that doesn't work, see if you can run the Solver from the Excel environment. Enter your problem (or my sample problem). Make sure that your load attachment mechanism is "fixed". Get yourself a solution that is nearly correct (and don't ask me what I mean by "nearly"). Unprotect the worksheet. Fire up Solver. Set your objective cell to Q91, a value to be minimised. Set your changeable variable cells to E15:E18. Do not set any constraints. Run the Solver.
That will at least get you a solution. (To run Solver when the load attachment mechanism is "roller", the cell to be minimised is R91 and the cells that can be changed are E14:E18.)
Now for your other questions. (1) For a cable with no point load, give it a point load of zero somewhere near its midpoint. (2) You DO need to give an unstretched length for your cable, as it this that determines how saggy the cable is.
Please let me know how you go. At the same time tell me which version of Excel you are using, and which version of Windows. I thought I had got around the "VBA reference" problem, but maybe not.
If this issue is going to become a "support" issue, it might save other Eng-Tippers from boredom if you contact me directly, using the e-mail address that is on my web site. but I'm not overly fussed either way.
Cable configuration must conform precisely to the shape of the bending moment diagram of a simple span beam of length L. Any type of load can be used, uniform, variable, concentrated or any combination of these. Whatever the load, the cable will deflect precisely in accordance with the bending moment diagram.
In particular, a cable which carries a uniform load from end to end will assume the shape of a parabola. The sag may be changed but it will still be a parabola.
A cable which carries nothing but its own weight will assume the shape of a catenary. If the sag is large, the load per foot of span is higher near the supports than at the center.
BA
Do you know how the Radius X Stress rule on that page is derived to give the cable tension?
The problem I'm usually presented with is just a tension fabric structure with the fabric almost indicatively drawn in. A beam with uniform UDL gives a parabolic BMD? If so, then I guess stick with the wL^2/2s approximation I've been using?
Yes. If a cylinder has uniform internal pressure, every part of the circumference feels a radial pressure P. Cutting a section through the middle of the cylinder parallel to the axis in any direction, the total pressure acting on either side of the section is P*D where D is the diameter. Each wall takes half of that, or P*R. It is the same with a cable if it assumes a circular configuration. It is not true if the cable assumes any other configuration.
If the load is uniform, the cable is parabolic and the horizontal component of the tension is wL2/8s...not wL2/2s as you just stated. Whether or not the cable is parabolic, the horizontal component of the cable tension is M/s where M is the simple span moment at any point and s is the sag at the same point.
The maximum cable tension occurs at the supports and as should have been stated earlier is (V2+H2)1/2. Please note I had a typo in my earlier post.
BA
So it comes down to calculation of the "Moment", which is dependent on cable shape.
Calculate this moment and divide back by the lever arm, Sag, and we have a component of Tension.
Assume Circular - Tension = P * R
Assume Parabolic - Component of Tension = wL^2/8s
Assume Hyperbolic/Catenary - Still not sure here. Uncertain on the 'a' scaling factor in the Catenary Formulas.
The scaling factor depends on the unloaded length of cable. Say the span is L and we have a point load at 'a' from the left support and 'b' from the right support (a + b = L). Neglecting the weight of the cable, the maximum moment occurs at the load and has a magnitude of Pab/L. If the sag is s at the load point, H=Pab/Ls. The moment diagram consists of two straight lines and that is also the configuration of the cable, two straight lines. The overall length of cable is (a2+s2)1/2 + (b2+s2)1/2 which is equal to the initial length of the cable plus the stretch due to tension. The tension will be the slope component of H which will be different on each side of the load except when it is at midspan.
Whatever the load is determines the moment diagram and the shape of the cable is similar. I hope that is clear now.
BA
