Toe nail fungus PinPointe Laser
Here is a link to the laser one of the companies in my area is using to remove toe nail fungus. The PinPointe foot laser spec sheet :
http://www.cynosure.com/download/pdf/m6255-PinPoin...
1. Is this the only laser proven to cure toe nail fungus?
2. Would selecting a different laser with the same "wavelength" and "power density" be sufficient to have the same effect in killing/removing toe nail fungus?
3. Or would you have to consider other factors such as what modes are propagating?
Thank you
