User defined results in APDL
hi every body
I would like to plot contour of some expresion in ANSYS APDL
the equation is sigma:epsilon+const sigmma-tensor,epsilon tensor
Is it possible in ansys APDL to do it as a user defined results
if yes please how?
Thanku very much
if yes please how?
Thanku very much
RE: User defined results in APDL
Then you can operate with those vectors with *VOPER
And finally you can insert the result from the solution vector into the database with *VPUT (you have to overwrite a result you are not using with your custom result and then plot it with PLNSOL)
Look up these commands in the ansys help.
