Content of an Engine Build manual ??
What is the purpose of engine build manual? Whether it is used in engine assembly section or ll be provided to vehicle owner?
What will be its main content?
RE: Content of an Engine Build manual ??
It is of little value to the typical owner unless he wants to DIY an overhaul.
It is of inestimable value to the owner of an exotic car or other vehicle that is not locally supported, so that he can lend it to a mechanic he trusts and have some hope of getting back a usable vehicle in a reasonable time frame.
Mike Halloran
Pembroke Pines, FL, USA
I think Mike is referring to a build log book that records everything done when repairing or more importantly modifying an engine.
A Factory Workshop Manual is used to repair a car to factory specification or to a factory recommended repair standard
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
Even low volume (1500/yr) production lines that I've seen, where the engine stays in place and the parts come to it, use an electronic step-by-step pictorial guide vs. a printed manual.
So they'd include which torque wrench to use (by model name), and its torque setting, bolt part number , washer part number, how many of them , what order to tighten them in, and what SPC is needed.
Cheers
Greg Locock
B.E.
