using symmetry in CORRUGATED Plate
Hi
My model has a beam with corrugated Web (using two L-Shape instead of Plain web) (attached picture). Because of big dimension, I’m going to use Symmetry. But is it possible when Web is not plain along the symmetry axis??
thanks
thanks
RE: using symmetry in CORRUGATED Plate
Symmetry is OK if the two parts are exactly the same and the loading would be exactly symmetrical.
Symmetry is nothing more than a constraint to move in a plane. So moving along the plane is fine, but if you expect to move through the plane of symmetry, you'll have unrealistic results.
