Multiple fixture offsets and canned cycles
Currently canned cycles aren't outputting the change in fixture offset, where's the correct place to insert the $mom_fixture_offset_value to fix the problem.
Using NX 8.5.0.23 and Post builder 8.5.0
RE: Multiple fixture offsets and canned cycles
Your G54, or whatever code you use should be added to the cycle parameters.
Do you have a block with the fixture offset defined?
John Joyce
N.C. Programming Supervisor
Barnes Aerospace, Windsor CT
NX6 & NX7.5
