Examples Heidenhain programs with drawings
Hello
thank you for entering in my post
I need to exercise myself with my iTNC530 programming station
I need some proper mechanical drawing which I can write at least 60 or 70 lines of program
And I'd like to compare my program with an example written in Heidenhain system and if I can compare also my parameters about feed speed ect... will be great
I need some proper mechanical drawing that reports also the material of the component
any suggestion according thi matter will be very appreciative
thank you in advance for your help
