Slopped spread footings vs. stepped footings for an Abumtnet or Pier, Pros and cons
What is the practical slope for spread footings?
RE: Slopped spread footings vs. stepped footings for an Abumtnet or Pier, Pros and cons
Flat. How steep do you want to go?
On my previous design, construction office prefered stepped spread footing. I am looking for a general information (code reference the best) and recommendations for the future projects. What slope contractor will be comfortable with to pour concrete. Thanks.
I have heard of a stepped streip footing, but never a stepped spread footing.
Mike McCann
MMC Engineering
http://mmcengineering.tripod.com
Sorry - strip footing... not streip. )(*&*%
Mike McCann
MMC Engineering
With steeper slopes and wide abutments it could be costly to pour it flat. I heard with stepped footings though contractor has problem to proper compact the base, besides it has to pause between segments to prepare the next one.
Go with steps, usually, we're only talking about a height differential of 2 or 3 feet. if you're on rock or a stiff soil it's not a problem to prep the base.
To msquared48: Sorry. I meant strip footing, not spread.
UBC used to allow 10% maximum slope
