Simple Tension test û why is my model too stiff?
Hi, I’m trying to validate my FEA models by using experimental stress-strain data from a composite tension test. I’m using NEI Nastran but for some reason the FEA results are way too stiff. I thought initially it was a material model issue so then I changed to an isotropic material – aluminium.
I have now done one of the simplest tests possible: 2D rectangle (with quad elements), fixed BC along curve at one end, force load along curve at the other end (low value so the model is always in a linear regime). The tensile modulus is 70.3 GPa, so logically after outputting the stress and strain results I expected to get the same answer back. However my results were once again too stiff and I had a predicted stiffness of 88GPa.
I really can't understand what is going on. I thought this was such a simple test.
Thanks for any help
Thanks for any help
RE: Simple Tension test û why is my model too stiff?
are you accounting for poisson effects in your hand calc ?
Quando Omni Flunkus Moritati
http://www.eng-tips.com/faqs.cfm?fid=376
http://www.eng-tips.com/faqs.cfm?fid=1083
