LN standard parts
LN standard parts
LN standard parts
Hi everyone!
I am new here in the forum, and I hope someone can help me. Does anyone know where I can get LN components (german standard for aeronautics components)? I am having a hard time finding someone who manufactures or supplies this type of components. I found a company in Germany that produces these components, but the price is pretty high and I am looking for alternatives.
Best regards and thanks in advance!
RE: LN standard parts
I worked for close to 30 years in the USA on German aircraft and never found a supplier in the US for LN bolts. I either bought from the aircraft manufacturer, or from a company in Germany. The price is always about 3 times as high as you think it should be. As an alternative look at DIN specs. Some German aircraft Mfg's use DIN bolts in non critical applications.
Try these people: Industrio GmbH
Dreichlinger Strasse 79
92318 Neumarkt
Germany
Tel: +49 9181 29720-0
Fax: +49 9181 29720-130
Mail: sales@industrio.de
B.E.
@Berkshire:
Thank you for your answer, I'll contact them and ask for a quotation to compare with the ones I already have. My problem is that the parts we are working on are going through a severe vibration test, so the bolts will withstand enormous tension. And I have looked for DIN specs as an alternative, but our customer has specified these kind of bolts.
Anyways, thanks for the info, I'll give it a try!
PS: The company I talked about is Johann Maier, in case you might need another supplier. I cannot tell much about them, but all I heard from them is good things.
@TVP: Thanks for the tip! I have already contacted them, I am waiting for their answers.
