Minimum Wall thickness requirement for Pipe per ASME B31.3
Is there any requirement specified in ASME B31.3, regarding pipe minimum wall thickness. Just like ASME Section VIII Div. 1 specify minimum requirment for plate thickness for pressure vessels, i thought there might be some clause in ASME B31.3 as well.
Meck91
Meck91
RE: Minimum Wall thickness requirement for Pipe per ASME B31.3
Paragraph 304:
t= PD/ 2[(SEW/I)+PY]
You have to take into account the mill underrun tolerance per the purchase specification you're designing the piping system for.
This is included in the part of T > tm = t + c. Usually the tolerance is 12.5%, but it can be different.
(a) For t < D/6
or
t={P(d + 2c)}/{2[SEW − P(1 − Y)]}
b) For t ≥ D/6 or for P/SE > 0.385
Calculation of pressure design thickness for straight pipe requires special consideration of factors such as theory of failure, effects of fatigue, and thermal stress.
