Gouge checking
Gouge checking
Gouge checking
What clearances and tolerances is the Gouge checker using? Is there a tool holder and shank safe distance for the IPW during 2D dynamic verifying? Why varies the number of collisions, if I run Gouge check more times? When verify says No collisions, why says Gouge check there IS collisions? Are the 10-parameter tools supported?
In which should I trust? mad
kukelyk
