Maximum tool length using a journal
Hello.
Is there any way to get from CAM operation maximum tool length using journal code?
Maximum Tool length should be taken from top of a geometry (it could be a selected point)
In other words I'm trying to get the minimum "Z" coordinate of tool path according to "MCS Z axis" computed from a selected point.
Best Regards
Best Regards
RE: Maximum tool length using a journal
What You write is minimum Z, but the holder may go under blank top plane safely..
kukelyk
