Rapid Prototype of Fairing for End Use Product
I'm basically in the process of designing a junction style fairing that will wrap around some butted tubular sanctions on a modified aircraft. They are somewhat complex fairings and they need to be manufactured in a timely manner. I do not have a lot of experience with composite materials nor rapid prototyping. So anybody have any recommendations on a process/material to make these one-off fairings that will be strong enough to fly on an experimental aircraft as an end product? Fiberglass, Kydex (or some other rapid forming thermoplastic) I'm even open to 3D printing options if there's a industry standard out there for doing it.
RE: Rapid Prototype of Fairing for End Use Product
airspeed ? (sub-sonic ?)
scale of airplane ? ... (large, medium, small, UAV)
permanent (like fiberglass moulded onto the staunction (?)) or removable ?
Quando Omni Flunkus Moritati
Not exactly, but something similar to this concept from a Cessna on aircraft spruce's website, http://www.aircraftspruce.com/catalog/appages/sten...
you could make up a two piece fairing like your link ... sheet metal if you don't need to fair into the wing/fuselage (like the cessna one does) ... maybe bend the s/m over a slightly smaller tube than your stanuction (so it'll wrap your stanuction well) and bend tabs to pick up the skin (bending a full flange would be too difficult unless you've got a full shop to work with ... heat treat, form, re-heat treat). make the trailing fairing out of two pieces rather than one with a really tight bend on the T/E, again bend tabs to pick up the skin.
0.032" 2024 would be plenty, maybe 0.025" (much easier to work with).
or make same from fiber-glass ... room temp cure
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Aluminum casting? Wouldn't that require a ton of machining to make a mold for? Something I'm trying to avoid unless the mold can be made of something non-metal that doesn't require a ton of tooling hours to make. There's only going to be 4 of these.
Here's the collaboration website with the link to the picture. https://saicbw.teamplatform.com/pages/43339?t=8hcs...
I am going to give you two options , there are many more.
For this low a volume, find an aircraft sheet metal mechanic that can do hollowed out/ formed shapes i.e. nose bowls for engine cowlings.
Get him/her to pound them out on a sandbag, power hammer, english wheel, or whatever else is to hand. The labor cost is high for this type of work , but you only need 4. They will be a finished part you can put on the aircraft.
If you use 3000 or 6000 series aluminum you can weld the spigots onto the main part of the fairing
Option 2 make plaster/ tool rock molds for part, lay up composite part. looking at your piece you may need a left hand ,and right hand mold.
If you want a smooth surface, make female mold from toolrock part. Then depending on strength desired you can use room temp open lay up, or prepreg from any one of a dozen different materials.
B.E.
I think a glass fibre splash over a wooden mould is the way to go, but given that the part is reentrant you might want to go with afemale mould and lots of split lines.
Bashing sheetmetal with a hammer and then brazing the parts together is certainly a possibility
Cheers
Greg Locock
Anyway, I'm still really keen on sending out a model for 3D printing. Anybody have any experience with this similar to the application I'm trying to do? Since this is not a structural part and just needs to take on the aero forces I feel like 3D printing has come a long way to suffice for this application. What are opinions on the best type for me to research? FDM is my best conclusion so far. Or maybe still leaning toward some kind of thermoplastic. Any website links would be helpful for me.
You could put a release layer of Saran on the pod and the stanchions, bulk up the fairing in situ with modeling clay, or styrofoam, or balsa, or whatever, apply the tape, then optionally a layer of Saran and some balloons and duct tape to smooth out the surface texture and densify the part, working _rapidly_ of course. ... or use a slower curing prepreg and work carefully.
RP machines in general, especially the 'affordable' ones, have a pretty limited build envelope. The biggest RP part of which I am personally aware is a custom developmental intake manifold for a Big Block Chevy, built in four parts with mating dovetails. The producer (also incidentally a RP machine retailer) asserted that epoxy parts lasted long enough for testing; the heat riser channels charred but didn't burn through right away. The RP parts were only used long enough to get dyno and field test data; the good ones were replicated in aluminum for production.
Mike Halloran
Pembroke Pines, FL, USA
"anything they build would have to be derived from technical drawings" ... only if your guys are thicker than planks ... good shop guys should be able to work from a sketch on a "fag packet" (which isn't, of course, a gender preference slur).
why the focus on "rapid prototyping" ? is this a one off or a production run ? fairing something on a DHC-8 is pretty much cosmetic ... any sort of fairing will do, maybe something with a 20deg angle. i wouldn't bland into the mating surface ... i'd use a P-seal to interface (to protect the mating surface).
and once you have your prototype, you'll have to make an engineering part out of it. mike's suggestion of fiber glass (as in arm casts) is certainly rapid but is it certifiable ? the problem being prove it doesn't "depart the airplane in an unsafe manner (should it choose to do so, ie depart (= fall off) the airplane)".
if you reaaly mean rapid prototype ... styrene foam and "speed tape" would work to give you a good shape (and easy to adjust) to productionise.
This is a
onefour-off production run. And the fairing isn't part of the DHC-8 OML. It is a "trussed" style structural frame that runs up into ttached pods on the aircraft and suspends a antenna ground plane on the underside of the aircraft. The structural frame is fair'ed and this is where the sanctions all come together on the pod. Very hard to explain I know.I refer to rapid prototype that will also be used as an end product too, or engineering part per say. The 3D file is used for the design activity and is QA'ed with. I'm really trying to explore these options for a few reasons. We (my company) does the design/engineering. Another company does the integration of our designs. So the way the contract is set up my company would have to contract another company to come in and do the molding work and then we document to build for another one or capture what was done. It's hard to run down the logistics of the contract, but doing reverse-engineering is costly and time consuming on our side. My interest in 3D printing is that there is no costly tooling to make for an one off composite part and lead times are short. Problem is there's several different techniques to this and material properties are shady from my research. Even using something like Kydex is an option. But I just don't know how labor intensive making a mold is for shrinking the shape to is would be. Bottom line is that I have the shapes. Who (links if possible) can I send 3D files to and can make an end product.
seriously, why fair the struts ? is flight in icing a concern ? is the pod the junction of the truss, or do multiple legs pick up on the same pod fttgs ? the latter is harder to fair ... fiber glass is the only way there ... make a dummy fairing from polystyrene and use this to create the fiber glass fairing. the struts can be faired either with fiber glass or sheet metal ... i'd mount these pieces off the legs and use them to secure the fiber glass fairings.
personally, the most i'd do (being a -8 guy) would be to "squeeze" the round tube into streamline shapes (and keep the round tube at the ends for easy of joining.
Also, there are cables that will run from the inside of this pod down to the ground plane via the strut fairings. Even if the CFD data was good those cables can't be exposed environmental factors and need to be shrouded.
Anyway, take a look at the collaboration site link. Any input on the shape is accepted as well. I'm not an aero guy by far. Just keep in mind my original comment about sourcing this to a third party manufacturer to build.
I suggested "Tool rock" thinking that you wouls be fabricating parts from a drawing in a tool shop setting.
From what you are saying you have the brackets for your pod already mounted on the aircraft together with the struts.
Now if you want to get down and dirty, you can take a plastic bag full of two part self expanding foam, wrap it around the fairing junction, wait for the foam to expand and to harden, then whittle away anything that does not look like a fairing. Carefully cut the result into two or three pieces to remove it then putty and smooth the outside. you can tape that on and use it for a test flight article, modify it as needed then use the final result as a basis for a mold or a final drawing. You cannot do production and QA until you have a final result that is satisfactory to all of the participants.
B.E.
Yes, the pod and struts are mounted on the aircraft now. The task is to fair in the traffic jam of struts and the flat bottom part of the pod.
I do not want to get down and dirty sorta speak. Meaning I have already have my shapes in 3D CAD now and that is my mock-up....3D printing will be the physical prototype. The original part of my question is has anyone used this type of application or other rapid prototype methods derived from 3D models to be used as and end product as well. The process of getting there isn't primary concerning to me -unless- it alters the manufacturer-ability of my overall design. I'm merely only going to accept the final product that derives from my intent. Whether that's a rapid prototype method or me sending drawings out for a third party vendor to make.
Also ask what file format they prefer, so you can generate the appropriate files from your solids. You shouldn't need to send drawings except for reference purposes.
I suggest adding some self-aligning/ self-fixturing features (e.g. dovetails) to help in assembling the parts.
This would also be a good time to ask about what materials are available (lots) and what mechanical properties they will guarantee (probably none). I'd expect the produced articles to be anisotropic, e.g. relatively weak in the Z-axis direction. Ask for any quantitative data they might have.
Note that the surface finish in the Z-axis direction is also usually pretty bad, because striving for good finish in that direction, i.e., thinner layers, increases build time, and price. Anyone doing the assembly of sub-parts will need sandpaper and Bondo or similar.
Mike Halloran
http://www.3dsystems.com/
I am not affiliated with these people.
B.E.
cover the shape with "speed tape" or glass fiber. i'd suggest the former for flight test, get satifsactory results then productionise it ...
you'll need to think about joining segments together (shouldn't be too difficult ... use sections of the 3D printer output, carve away a little to allow for an overlap,
you'll need to think about how to attach to the struts, probaby little stand-off brkts,
and seals to protect the mating structure
From the Rapid Prototype plastic parts I've played around with I'm not sure they'd be my first choice for in airflow flight components but I may be missing a trick. I've done some FDM parts made from ABS and they were good enough for production on in lab scientific instruments. However, some other parts that 'clipped on' proved a bit too fragile and couldn't take many cycles - if nothing else I suspect the layering caused some stress raisers.
From the links I couldn't size information. Large rapid prototype parts get expensive quick.
David
I have just been through installing stuff into a Dash-8. Getting everything approved can be very exciting. Make sure you know how you will accomplish this.
I am not aware of a rapid prototyping material that will not give off nasty gases when it burns. Do not rely on direct rapid prototyping. If you go to glass or carbon fibre reinforced plastic, be careful what grade of plastic you select.
Rapid prototypers can produce wax patterns, suitable for investment casting.
JHG
I'm in contact with a guy from Stratus to see if they have any case studies using FPM parts on this type application. Either way I do it there has to be documentation on it. Even if this is a one off deal, the customer requires documentation to reproduce these if they get damaged during mission. Unfortunately it's QRC and a program of record wrapped into one.
Any good reading material out there on exactly what a fairing drawing entails?
I looked through my stack of drafting books and could find nothing specific to Fairing drawings.
It would come down to basic drafting skills.
In the past for a fairing Drawing, when I have had to do them, enough information has to be given to the mechanic to allow him to manufacture the component.
the process has been to set up stations at regular intervals across the part
Then waterlines or section views.
Each of these has been dimensioned to allow the mechanic to make an eggcrate model of the part.
He can then use this information to make a mold, pattern, or directly hammer the part out of sheet metal using the eggcrate model as a guide / gage.
You already have a solid model of the part. Make a drawing from the model then give enough section views with dimensions as supplimental views to allow the part to be made either with or without a 3D printer. This way a shop can Beat them out of sheetmetal, Thermoform Kydex, cast them, Machine them out on a CNC mill, or print them out on a 3D printer, either way you would have given enough information to get the job done.
B.E.
I got off on a bit of a tangent here and started thinking 2D, you want to keep this 3D, you need to look up ASME Y14.41-2003 for what you are trying to do.
During the flight test program to get the wing stores certified for our GV, we had to prove to the FAA that those stores would not adversely affect flight when they were covered with ice, so we created some "ice" from parts printed in our old Dimension (ABS FDM) printer. Worked really well for that application, but the parts were hardened somewhat with a coating of epoxy and floor-dry (like kitty litter) that was simulating a "rime ice" texture. These shapes survived just fine at GV speeds all the way to 51,000 feet....
Steve R.
my idea was only to use the 3D printed bulk fairing was for flight test ... print your CAD file (including holes for the staunctions), stick it on the plane, speed (or duct) tape it to keep it from getting blown off, modify it as necessary. then use the final shape as a mounld for a glass fiber fairing.
if "Either way I do it there has to be documentation on it." then i guess you're slightly screwed. As a flight test installation, the pilots flying and the engineer organising the show need to be satisfied. i'd've thought the use of speed tape was pretty universal. i'd've thought adding a fairing like this was pretty innocuous, there might be more of a question if this is on the fuselage roof (ie things flying off impacting the H. Stab).
Drawoh, I believe there are at least some flame rated plastics used with rapid prototyping, Ultem for instance.
Chris843 we've used these guys for some parts and they do have some Aero industry involvement by the looks of it. https://www.solidconcepts.com/
