tabular spacing is missing in BlockStyler listbox
hello ,
I have made a vb Block styler program to search from in a text file .
But when I put selected string lines from the "searched" array list into the BlockStyler Listbox, the tabular space is missing. see attached *.pdf
alt.add(strline) >>> search line from text file in arraylist.
I have tried to output the variable strline into the nx listing window and msgbox, and both are showing correct with including spaces.
Only Listbox is ignoring spaces.
Maybe someone here know if it should be possible to included spaces in the Listbox ?
lklo
lklo
