Heat transfer tutorial in SE5 Simulation
I use SE for mechanical design and I am considering SE5 for heat transfer simulation. Are there any tutorials or guides available for heat transfer problems?
RE: Heat transfer tutorial in SE5 Simulation
Hello!,
Yes, you have examples of heat transfer analysis in ST5 SIMULATION, go to HELP.
Best regards,
Blas.
Blas Molero Hidalgo
Ingeniero Industrial
Director
IBERISA
48011 BILBAO (SPAIN)
WEB: http://www.iberisa.com
Blog de FEMAP & NX Nastran: http://iberisa.wordpress.com/
The only simulation tutorial built in to ST5 is for stress analysis, so you could learn from there and try to apply some of the same knowledge to heat transfer, or you can use the help tab or YouTube would be your best bet.
Tim
www.vmhinternational.com
