Can this masonry bearing wall be installed?
I am working on a project that involves cutting an opening in an existing cast in place concrete floor system (mild reinforced pan joists). Our intent was to utilize a new load bearing concrete masonry wall to support the existing pan joists. In this scenario the wall would be built with vertical steel to a bond beam that is located directly below the existing joists. After the masonry walls are installed the opening in the floor would be cut.
The contractor has indicated that he is unable to construct a wall like this. Can any of you provide input? Can this be done or am I asking the impossible? If it can't be done would there be a better way to do this?
RE: Can this masonry bearing wall be installed?
Most guys would prefer to use steel columns and beams and then shim them in place.
Have fun.
