Formula to calculate bending from point load on circular plate
Could anyone give me a formula to calculate the bending moment of a circular plate with a point load applied to the centroid. The plate to be designed as simply supported along the perimeter.
I know I can design it as a beam strip spanning 2 ways, but want a more accurate calculation.
The case is a 177 diameter plate with 250kN point load at centroid, can be applied over a 50mmx50mm area.
RE: Formula to calculate bending from point load on circular plate
you need to get your hands on a copy of Roarks Formulas for Stress and Strain.
It will have the formulas you need.
fixed or SS edges ?
thickness ?? (affects the solution in Roark (7th Ed, table 11.2, case 16 or 17)
Quando Omni Flunkus Moritati
