Solid Edge files to a format useable by Adobe Illustrator
(I'm a Tech. Writer... not a Mechanical Designer...)
Has anyone had any experiance with converting Solid Edge files to a vector format useable by Adobe Illustrator?
Here's my problem... we've tried converting Solid Edge files to AutoCAD R 14... when I try to open the DWG file in Illustrator, either the file is 'corrupt' and Illustrator can't open it, or curved lines either go missing, or are converted to circular objects.
I've never had a problem working with native AutoCAD files in Illustrator... so I don't know what Solid Edge is doing that might be causing the problem.
Any help would be wonderful.
RE: Solid Edge files to a format useable by Adobe Illustrator
for use on sheetmetal parts, I've never had a problem
saving Solid Edge Files as DXF or DWG files and reading
them into illustrator, apart from the fact that illustrator
does a poor job of scaling the file correctly.
I've been using a third party product called "CADGate"
which is an illustrator plugin and reads and writes
Autocad DXF & DWG formats and does a far superior job
than the built in translator provided by illustrator.
Have you tried writing a different dxf/dwg format out
of Solid Edge? I've been using V14.
This CADgate program looks interesting. I'll check it out.
Thanks!
Eilene
SO I CAN EMAIL DWG. TO CUSTOMERS WITHOUT CAD SOFTWARE TO OPEN AND VIEW.
We use Illustrator here to make thread-up diagrams for our manufacturing process. Our conversion takes a few steps:
1. Save your Solid Edge draft as a .dwg file.
2. Open it with Acad 14 or 2000 and export it as a .eps file. This type of file seemed to work best for us.
3. Import the .eps file into illustrator and verify scale.
I personally have never tried to import a part fiels or image. Hopefully this answers your question.
DNA
