How to update the Cue/Status Bar of NX using NXOpen?
Hello Friends,
Can someone let me know if it is possible to update the cue/status bar of NX with some custom message using NXOpen?
Amitabh
Amitabh
RE: How to update the Cue/Status Bar of NX using NXOpen?
I use
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpenUI
Imports NXOpen.UF
Module project1
Dim s As Session = Session.GetSession()
Dim ufs As UFSession = UFSession.GetUFSession()
Dim ui As UI = UI.GetUI()
Dim lw As ListingWindow = s.ListingWindow
Dim wp As Part = s.Parts.Work
then anywhere in the program the commands are
ufs.Ui.SetPrompt("Message for prompt line")
ufs.Ui.SetStatus("Message for status line")
Remember that many ui commands allow you to write messages to the prompt line.
Hope this helps.
Frank Swinkels
I will test this and get back if i have more queries.
Thanks once again for the prompt help.
Amitabh
