V5R9+VBA: Sub CreateSetofParameters+ SelectElement
Hi!!
i am having some Errors and i can´t advance any more, please if yo can help me...
1-
Does anyone know how does "Sub CreateSetOfParameters" work, which is the code? I try it and the following error comes
object doesn´t support this property or method
2-Whem I try to use SelectElement, the following Error appears:
Function or interface marked as restricted, or the function uses an Automation type not supported in Visual Basic.
Any solution or advice?
THANKS IN ADVANCE!
1-
THANKS IN ADVANCE!
