Non-geometric component
There is a few standart components in our tc8r if I put them into assemblie it shows nothing (in previe window there is no body), because they are non-geometric. How to change them to geometric? Where is the mistake, what is non-geometric component and how to change it. Man who created them was fired 3 years ago...
Thank you.
Thank you.
RE: Non-geometric component
If we right click on the component and select properties ..then in the assembly tab there is an option to toggle it off and on.(are you looking for the same)
Please check the image attached.
Best Regards
Kapil Sharma
There is a very detailed description given in NX documentation regarding the same.
Best Regards
Kapil Sharma
it worked.
Is it possible to add an attribute to a non-geometric part so that the Component is Non-Geometric toggle is automatically on when it is put in an assembly?
My guess is that this attribute (UG GEOMETRY with values YES/NO) cannot be set untill and unless the part becomes a component of an assembly.
Probably a little customization will do :)
Best Regards
Kapil Sharma
Best Regards
Kapil Sharma
