nxopen create a "point on face" with vb .net
Hello everybody,
I'm using NX8.0, and I would like to know if it is possible to create programmatically a "point on face" over U shaped faces or faces with hole(s) inside it, while being sure that the point is not within the gap/hole of the face.
In other words, how to make sure that the point created is over (in contact with) the face and not within the face's gap.
PS: except for the corners, the position of the created point doesn't matter.
Thanks in advance,
Nabil.
RE: nxopen create a "point on face" with vb .net
Here is a vb journal to create a point on the face at the face selection point.
CODE -->
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.Utilities
Module Select_Point_on_Face
    Dim s As Session = Session.GetSession()
    Dim ui As UI = UI.GetUI()
    Dim ufs As UFSession = UFSession.GetUFSession()
    Dim workpart As Part = s.Parts.Work
    Sub Main()
        Dim response As Selection.Response = Selection.Response.Cancel
        Dim prompt As String = "Select Position on Face"
        Dim temptag As Tag = Tag.Null
        Dim cp(2) As Double
        Dim face1 As Face = Nothing
        Dim facetag As Tag = Tag.Null
        Dim point1 As Point = Nothing
Start1:
        facetag = select_point_on_face(prompt, cp)
        If facetag = Tag.Null Then GoTo End1
        face1 = NXObjectManager.Get(facetag)
        Dim pnt3d As Point3d = New Point3d(cp(0), cp(1), cp(2))
        point1 = PointFeatureOnFace(pnt3d)
        GoTo Start1
End1:
    End Sub
    Public Sub map_view2abs(ByRef c() As Double)
        Dim vname As String = ""
        Dim abs_mx() As Double = {0, 0, 0, 1, 0, 0, 0, 1, 0}
        Dim vw() As Double = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0}
        Dim mx() As Double = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0}
        Dim irc As Integer = 0
        ufs.Ui.AskLastPickedView(vname)
        Dim wp As Part = s.Parts.Work
        Dim lastViewPicked As View = CType(wp.ModelingViews.FindObject(vname), ModelingView)
        Dim vmx As Matrix3x3 = lastViewPicked.Matrix()
        vw(3) = vmx.Xx
        vw(4) = vmx.Xy
        vw(5) = vmx.Xz
        vw(6) = vmx.Yx
        vw(7) = vmx.Yy
        vw(8) = vmx.Yz
        vw(9) = vmx.Zx
        vw(10) = vmx.Zy
        vw(11) = vmx.Zz
        ufs.Trns.CreateCsysMappingMatrix(vw, abs_mx, mx, irc)
        ufs.Trns.MapPosition(c, mx)
    End Sub
    Public Sub map_abs2view(ByRef c() As Double)
        Dim lastViewPicked As View = _
        vw(3) = vmx.Xx
        vw(4) = vmx.Xy
        vw(5) = vmx.Xz
        vw(6) = vmx.Yx
        vw(7) = vmx.Yy
        vw(8) = vmx.Yz
        vw(9) = vmx.Zx
        vw(10) = vmx.Zy
        vw(11) = vmx.Zz
        ufs.Trns.CreateCsysMappingMatrix(abs_mx, vw, mx, irc)
    End Sub
    Public Sub ask_pos_on_obj(ByVal obj As NXOpen.Tag, ByVal loc() As Double)
        Dim aLine As NXOpen.Tag = NXOpen.Tag.Null
        Dim cp() As Double = {0, 0, 0}
        Dim dist As Double = 0
        Dim lp As UFCurve.Line
        Dim sp(2) As Double
        Dim ep(2) As Double
        lp.start_point = sp
        lp.end_point = ep
        map_abs2view(loc)
        lp.start_point(0) = loc(0)
        lp.start_point(1) = loc(1)
        lp.start_point(2) = loc(2) + 10000
        lp.end_point(0) = loc(0)
        lp.end_point(1) = loc(1)
        lp.end_point(2) = loc(2) - 10000
        map_view2abs(lp.start_point)
        map_view2abs(lp.end_point)
        ufs.Curve.CreateLine(lp, aLine)
        ufs.Modl.AskMinimumDist(obj, aLine, 0, cp, 0, cp, dist, loc, cp)
        ufs.Obj.DeleteObject(aLine)
    End Sub
    Public Function mask_for_face(ByVal select_ As IntPtr, ByVal userdata As IntPtr) As Integer
        Dim num_triples As Integer = 1
        Dim mask_triples(0) As UFUi.Mask
        mask_triples(0).object_type = UFConstants.UF_solid_type
        mask_triples(0).object_subtype = 0
        mask_triples(0).solid_type = UFConstants.UF_UI_SEL_FEATURE_ANY_FACE
        ufs.Ui.SetSelMask(select_, _
                UFUi.SelMaskAction.SelMaskClearAndEnableSpecific, _
                                          num_triples, mask_triples)
        Return UFConstants.UF_UI_SEL_SUCCESS
    End Function
    Public Function select_point_on_face(ByVal prompt As String, _
                                          ByRef cp() As Double) As NXOpen.Tag
        Dim resp As Integer = 0
        '    Dim thing As NXOpen.Tag = NXOpen.Tag.Null
        Dim theView As NXOpen.Tag = NXOpen.Tag.Null
        Dim mask_face As UFUi.SelInitFnT = AddressOf mask_for_face
        ufs.Ui.LockUgAccess(UFConstants.UF_UI_FROM_CUSTOM)
        ufs.Ui.SelectWithSingleDialog("Select a face", prompt, _
                    UFConstants.UF_UI_SEL_SCOPE_ANY_IN_ASSEMBLY, _
                     mask_face, Nothing, resp, facetag, cp, theView)
        ufs.Ui.UnlockUgAccess(UFConstants.UF_UI_FROM_CUSTOM)
        If resp = UFConstants.UF_UI_OBJECT_SELECTED Or _
           resp = UFConstants.UF_UI_OBJECT_SELECTED_BY_NAME Then
            ask_pos_on_obj(facetag, cp)
            ufs.Disp.SetHighlight(facetag, 0)
            Return facetag
        End If
        Return Tag.Null
    End Function
    Public Function PointFeatureOnFace(ByVal where As Point3d) As Point
        Dim markId1 As Session.UndoMarkId = s.SetUndoMark(Session.MarkVisibility.Visible, "Create Point")
        Dim point1 As Point
        point1 = workpart.Points.CreatePoint(where)
        Dim nullFeatures_Feature As Features.Feature = Nothing
        Dim pointFeatureBuilder1 As Features.PointFeatureBuilder
        pointFeatureBuilder1 = workPart.BaseFeatures.CreatePointFeatureBuilder(nullFeatures_Feature)
        pointFeatureBuilder1.Point = point1
        Dim nXObject1 As NXObject = pointFeatureBuilder1.Commit()
        pointFeatureBuilder1.Destroy()
        Return point1
    End Function
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        '----Other unload options-------
        'Unloads the image immediately after execution within NX
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
    End Function
End Module
Frank Swinkels
Hello Frankswinks,
thank you very much for your quick answer.
It is a really interesting code however what I need is module that adapt to any face shape and create a point on the face while avoiding the eventual gap on the face and the corners. The ideal would be the nearest position near the centroid but it is compulsory.
I cannot use directly the centroid because if the face has a U form the centroid is created in the gap in between.
Thanks again for your help.
Sincerely,
Nabil
