UG-101 revision
UG-101 revision
UG-101 revision
Does anyone remember when the safety factor changed from 5 to 4 in UG-101? Did it coincide with the changes in allowable stress that came with the 1999 Addenda? Thanks for dusting off the memory banks...
RE: UG-101 revision
You mean the change from TS/4 to TS/3.5.
RE: UG-101 revision
and it was the 1999 Adenda.
RE: UG-101 revision
I was actually wondering about the change in safety factor for rate by burst, in UG-101. I could see how it could be related to the 1999 change in safety factor vs ultimate, but was not sure they happened at the same time. Thanks for the responses...
