Utility Back-feed
Utility Back-feed
We have 3X 4000hp MV motors. The idea was to have 2 VFDs so that the first two motors can be started by the 2 VFDs and if the 3rd is required, one of the already started motors can be placed cross the line and we can use the VFD to run the 3rd.
Problem is that utility company is concerned of back-feed from the motor placed across the line in the event of a fault and have basically said that a 3rd VFD is required to ensure no back-feed.
Any ideas on possible solutions to prevent back-feed?
RE: Utility Back-feed
I've never had a utility express this concern. It's possible that the fault current contributed by these large motors could be putting them over the rating of some of their equipment.
Unless this is a unique situation, I think the utility is being fairly unreasonable. It might be less costly to buy them a new recloser instead of another 4000 HP MV VFD.
This also means you are not allowed to ever run these motors on bypass in the event of a VFD failure.
