Help for bending moment calc with Roark's Formulas
I have a circular, flat strainer plate that is fixed at the periphery and loaded by internal hydrostatic pressure. The arrangement, mounted between flanges, is just like a blind flange, only thinner. I am seeking the bending moment at the periphery, and it is not obvious in Roark's Formulas which one to use.
At this moment (sorry) I am staring at Table 11.2, case 2e.
RE: Help for bending moment calc with Roark's Formulas
Not sure where you are, but you may be at the wrong table. In my copy (6th edition), I'm at Table 24, case 10.b. This gives
Mra = -q(a2 - r02)/8a2
where q is the distributed (constant) pressure loading from r0 to a, r0 being the inner radius of the pressure load, and a is the outer radius of the circular plate. If the pressure is acting across the entire plate, set r0 = 0. Note that Mra has funky units - it's a moment per unit line load per unit^2 thickness dimension. The explanation of finding stresses from the moments is given at the start of the table.
1 minute later:
You are exactly correct. I had scanned only through the sketches, of which only the simply supported variant is shown.
I assume that once I have Mra, the stress will come from the simple beam equation?
The stress is σ=6M/t2 as you may find in Roark's introductory notes.
prex
http://www.xcalcs.com : Online engineering calculations
http://www.megamag.it : Magnetic brakes and launchers for fun rides
http://www.levitans.com : Air bearing pads
I followed both formulae and I am getting a ridiculously high stress from the second one, plugging in a pressure drop of only 3 psi.
The local authority reviewer insists on including bending stress in the CRN application and I am stuck. Any suggestions?
From the formulae in my previous post σ=6Mra/t2=3qd2/16t2, so you see where's originating the formula above (of course a is radius and d is diameter).
If you have a thickness lower than tm from the formula above, then you are in troubles. I'm also assuming that your strainer has no holes at the periphery, otherwise things would be even worse.
prex
