Recommendations for Pressure Relief Valve Manufacturers
Is anybody aware of a pressure relief valve manufacturer that can do large valves (say 6" flange connections) suitable for Hydrogen service? We are in the process of designing a liquid ring hydrogen compressor and have run into a problem sourcing a non cast iron valve that would be suitable for the application, at least in the sizes we are talking.
Joe Hasik, CSWP
RE: Recommendations for Pressure Relief Valve Manufacturers
As this has been up for a while without an answer (and is close to being moved to page 2), may I recommend that you repost your question over on forum408: Valve engineering? You might get a better response there.
Want to know the do's and don'ts of Eng-Tips? Read FAQ731-376: Eng-Tips.com Forum Policies.
English not your native language? Looking for some help in getting your question across to others or understanding their answers? Go to forum1529: Translation Assistance for Engineers.
I'm not going to research hydrogen compatability and cast/non-cast, but the companies below make PSVs >= 6":
Anderson-Greenwood
Crosby
Leser Gmbh & Company KG
Sempell
Teledyne Farris Engineering
Dresser Industries (used to be Consolidated)
Mercer
Good luck,
Latexman
