Corner forming for sheet-metal enclosures
thread820-326262: Making a corner in sheetmetal for a dust tight box
This may be of interest to folks trying to form tidy sealed corners.
http://www.acf.at/lang/en/applications.html
A local vendor has this machine, the only drawback is that each corner shape (that is radius and wall height) requires a specific rolling tool. So, unless your supplier has a family of tools available to which you can match/adapt your design, you will have to pony-up for "your" tool. However, the results are exactly as illustrated.
It doesn't exactly answer the needs of the original posting but might be helpful to be aware of.
"You will master any feeling of inadequacy you may be having"
....from my fortune cookie @ the buffet!
