Circ and Rect Pattern Help
Hello All,
Thank you once again for helping me out so much! I do appreciate it! I'm trying to find the Circpattern command (or rectpattern) and can't find the button or the command anywhere. I know I've used it before (I'm primarily using GSD because if I recall correctly this does make a difference) I just can't find it. Help me please!
RE: Circ and Rect Pattern Help
In each workbench you have in View dropdown menu the Commands List...or use in Power Input field (lower right corner of CATIA window), c:commands list to see what you have in active workbench.
Fernando
https://picasaweb.google.com/102257836106335725208
https://picasaweb.google.com/103462806772634246699...
