Monorail support
Monorail support
Hi!
I'm designing a monorail which is support at three points. The monorail beam (I-beam) is bolted in its upper flange as shown in the enclosed sketch. Since it is a continuous beam there will be a bending moment over the middle support. My question is: Do I have to design the bolts for this bending moment or only for the vertical load? Is it depending on the rotational stiffness between the supports vs. the monorail beam?
RE: Monorail support
