Water well construction - question from the UK
Hi all,
I'm a British consultant working on an international project in Africa involving the drilling and installtion of a water supply well for a large residential/commercial development. A contractor has provided an outline design for the well including a description of "API steel casing" for the well casing and sump.
Is it common practice to use specifications and/or guidance from the American Petroleum Institute on a water supply well? I would have thought that a suitable standard from the AWWA or ASTM would be more appropriate.
I can point the contractor to British Standards, but I don't want to criticise his use of a US standard if it is a valid approach. Any advice would be greatly appreciated
Many thanks
Duncan
Many thanks
Duncan
Bashin' rocks and drillin' holes!
All models are wrong.
RE: Water well construction - question from the UK
