Crimp terminal
Crimp terminal
hi
does anyone know of a crimp terminal that exists, that is at 90 degrees to the spade.
so th cable would be at right angle to the spade part
( if that makes sense )
RE: Crimp terminal
RE: Crimp terminal
RE: Crimp terminal
Pretty sure piggy back spade connectors, when manufactured are just straight and then bent to the right angle.
RE: Crimp terminal
RE: Crimp terminal
Think that is not the bend direction you were looking for but maybe its better..or not
RE: Crimp terminal
thanks for idea, looks possible to use that in our case
also will try the bending of crimp
cheers
