carbon-molybdenum material used for A194 gr 4 nuts
Hi, Could someone tell me the material used for this all that is in the A194 spec is carbon-molybdenum
RE: carbon-molybdenum material used for A194 gr 4 nuts
The composition is in the ASTM A194 standard and you can see it at the bottom of this page:
http://www.portlandbolt.com/technicalinformation/a...
These parts can be produced with grade 4047 steel according to ASTM A29 or SAE J404.
do you know if there is an alternative European equivalent for 4047?
There is not a standard European grade that has the same or similar composition to 4047 according to SAE J404 or ASTM A29. High temperature fasteners in the EU are specified according to EN 10269, with a more highly alloyed steel such as 42CrMo4 being commonly used.
