Catia v5 change mouse cursor size
Hello
I got a little problem with mouse cursor size, when i had to select small objects like points ect. ect.(the hand with pointing finger),because it's too small it become difficult to select those objects rapidly. Even when I press ALT + left mouse button (the object I try to select will not be listed, atleast at the first try) There is any possibility to increase the size of the cursors?
Tanks anyway
Tanks anyway
RE: Catia v5 change mouse cursor size
Another suggestion: Usethe User Selection Filter to only select points.
(why is it so difficult to add pictures here?)
Tanks for the time spent.
I solved my issue using your suggest (selecting 10 for window size) in addition i also activated the accurate picking check mark and changed the value to 3.
Now it works fine even when I use the ALT+left mouse button for picking list.
