CO2 removal process with amines
Hi everyone,
I would like to know what happens in an CO2 removal process with amines when we increase the CO2 concentration at the inlet of the absorption tower. Does the separation efficiency decrease or increase? Can anybody justify it?
Thank you so much.
Thank you so much.
RE: CO2 removal process with amines
Also it depends on which amine you are talking about
This is a nice resource to look at:
Aspen HYSYS Simulation of CO2 Removal by Amine Absorption from a Gas Based Power Plant (PDF file)
I hope that helps.
Allan S. Hugo, Ch.E.
Editor, ChemBookStore
"Build a strong chemical engineering library"
http://www.chembookstore.com/
