bendy plastic
bendy plastic
bendy plastic
Can somebody please tell me what type of plastic this is moulded (the arm that clips over the chair)from and the moulding method? I assume some sort of Polymer that is injection moulded?
I cant find a bigger picture so I hope this is enough..
[img ]
I need to design a bendy component using this material.
RE: bendy plastic
My first guess would be injection molded polypropylene.
There are other possibilities.
If you want to find out what was used in that particular part, buy a sample and measure their mechanical and thermal properties.
Mike Halloran
Pembroke Pines, FL, USA
