Deleted or invalid class ID was used
thread561-313665: Save failed with "a deleted or invalid class id was used"
If I try to delecte or edit a certain sketch in a file I get a failed to to save with the above error
I've tried aprt cleanup bith before and after deletion to no avail.
I've recreated the sketch and replaced everything it's attached to and suppressed it but I'd prefer to be able to get rid of it completely in order to avoid confusion and problems with downstram users.
Any suggestions?
Any suggestions?
RE: Deleted or invalid class ID was used
Copy the complete history of the part file (except the erroneous sketch) and paste it another part file.Please do a check and then save it (with the same name and replace the original).
Sorry at this moment i am assuming that the model is not having any drafting attached to it and this is a standalone part file only.
Best Regards
Kapil Sharma
Best Regards
Kapil Sharma
