Cast Iron Bore Press Fit - Sleeve Material Selection
I have a cast iron bore (4.5" diam.) into which I would like to press fit a sleeve. I am calculating the contact pressure for such a fit and trying to tailor my sleeve thickness and sleeve material selection. Can anyone recommend a good sleeve material? I would like the fit to be a relatively light press fit, therefore the press fit length would be short (0.125"?). The Overall sleeve length is about 1".
Any suggestions on this application would be appreciated.
RE: Cast Iron Bore Press Fit - Sleeve Material Selection
Cockroach
1000s of psi hydraulics?
A stationary O-ring"
Rotating seal?
Lip seal OD?
Is the sleeve going to be mechanically retained axially with a cover?
