Wind turbine generators
Why do most wind mills use Induction generator to produce electricity?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Wind turbine generators
The are inexpensive {but generally require reactive-power support.}
https://www.altenergystore.com/cart/catalog.html
click on Wind Generators under Products
that will bring you to the wind generator manufacturers and fairly detailed generator specifications. The above link is specialized to Alternative Energy products and info.
The induction generator is simpler and more reliable power source when aligned with the windmill prime mover.
