Vacuum Breaker Valves for Water Tube Boilers
Do they make vacuum breaker valves for industrial water tube boilers? I have a 60,000 lb/hr boiler that produces superheated steam of 650 deg F at 400-psi. The boiler has been running in bad shape for a few years now. Tere are times when this boiler is on standby mode and vacuum conditions exist inside with steam condensing. I don't have alot of experience with vacuum breaker valves but any help would be greatly appreciated
