PMI included in a JT?
I'm trying to include PMI data into a JT export file, but when I open the JT file to check it there's no PMI!!
Any ideas
RE: PMI included in a JT?
What version of NX are you running?
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
John, thanks for getting back to me. Seems i needed to re-save my congig file after i logged back in today. Works fine now.
John, gamura,
I'm having the same problem with NX6.0.5.3 and 8.5.2.3 (being piloted prior to TCUA upgrade). I have checked my user prefs and the JT preferences. Include PMI is checked, but for the life of me I can't get the PMI to come in with JT in TC-Vis or JT2GO. What should I be looking for?
Thanks.
I think you'll need to contact GTAC for this issue.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
John,
Unfortunately we're in the middle of annual contract negotiations w/ Siemens, so I can't open a GTAC tiket for a few weeks. Thanks for responding.
I was having the same problem. Then I discovered I needed to change some settings in JT2Go to see the PMI.
In JT2Go
1) From the Tools menu, select PMI
2) Right Click on geometry in the display window and select Toggle in PMI Tree.
3) Click on the PMI tab at the bottom of the tree navigator and expand the views to select the views which have PMI in them.
There may be other settings that you want to change from PMI -> Preferences
