Reliability of Nylon Anti-Vibration Patch on Repetitive Usage
The application requires a repetitive usage of a screw nylon-patched, McMASTER-CARR P/N 96562A020.
That is, the patched screw should be used over again for 10 times without replacement to a new patched screw and without loosing function of anti-vibration.
I understand the requirement is wrong, but I need to prove out a trash hold number of repetive usage of patched screws.
Do anybody out there have a data showing that the nylon patch is wore out after certain times of repetive usage?
Do anybody out there have a recommendation of trash-hold numbers of repetive usage based on reliable experiences?
Million tahnks in advance.
jpark@imsco-us.com
John Park
jpark@imsco-us.com
John Park
RE: Reliability of Nylon Anti-Vibration Patch on Repetitive Usage
This question should be asked in forum725: Welding, Bonding & Fastener engineering.
Please do not double post. Red flag your post here, and the administrators will delete it.
JHG
