HSLA RB-80 steel used in Unground Bearing Outer Raceways
Has anyone ever heard over unground bearings using outer raceways manufactured from HSLA steel. Any input appreciated. I have put forth alot of effort into actual life/load dynamic testing and comparing to standard bearings using low carbon grade steel stamped outer races that have been case hardened with basically no success even at 1/2 load rating applied to HSLA outer races. Bearings are running at 60 surface feet a minute for comparative testing, both grease and oil have been run still no success on HSLA. Heavy ball paths are worn into the HSLA. Thoughts anyone?
RE: HSLA RB-80 steel used in Unground Bearing Outer Raceways
Why?
Mike Halloran
Pembroke Pines, FL, USA
http://www.ntnamericas.com/en/website/documents/br...
general bearing race material pressure limits in attachment, from INA catalog 307
Mike Halloran
Unfortuneately.....where they at?
Mike Halloran
